Windows 8 possible?
Windows 8 possible?
Wondering if anyone has tried using the windows 7 method to get windows 8 operational on a cf-30. Thanks in advance.
- copracer1990
Re: Windows 8 possible?
Did it on a CF30 MK1 (CF30CCS80BM) with no issues, other than my Build 9200 needing activation... I also did it on a MK2 (CF30FCS80AM) and the "Brightness" control through W8 worked GREAT. I used all the Vista and W7 drivers...
If it isn't broken, take it apart to see why it is working!!
(1) CF30CCS80BM~TOUCHSCREEN~1.6GhzCORE 2~80g HD~4G RAM~EMISSIVE BACKLIT~INTEL 4965ABGN~GOBI~WINDOWS 7 ENTERPRISE~
(1) CF29LWQGCBM~TOUCHSCREEN~1.6Ghz~1.5G RAM~RUBBER BACKLIT~INTEL2915ABG~80g HD~WINDOWS 7 ENTERPRISE~
(1) CF27LBAGHEM~TOUCHSCREEN~500Mhz~512MB RAM~DUAL BOOT XP & WIN98SE~60g HD~ EMISSIVE BACKLIT~GREAT FOR PROGRAMMING MY 2 WAY RADIOS~
(1) CF-M34~TOUCHSCREEN~unknown specs for running OBDII scanner~
you sir are a gentleman and a scholar!
Did you still have to update the BIOS to get the touch screen to work.
Looks like windows 8 works GREAT on a cf-30. Ive completed my first rig out of 16 today and all hardware appears to work very well. I DID upgrade the bios to vista version fyi. Just in case someone wants to take advantage of the inexpensive 40 dollar upgrades.
Wow! sounds like there is hope for getting Windows 8 Pro working right on the MK2copracer1990 wrote:Did it on a CF30 MK1 (CF30CCS80BM) with no issues, other than my Build 9200 needing activation... I also did it on a MK2 (CF30FCS80AM) and the "Brightness" control through W8 worked GREAT. I used all the Vista and W7 drivers...
Did you install Windows 8 system builder on a clean hard drive, or did you do an upgrade?
If upgrade did you go Vista to Windows 8 directly or did you install Vista, then Windows 7 upgrade, then Windows 8 Pro upgrade to get everything working right?
I just did an upgrade from Win 7 and the only thing I had to do was delete Microsoft Security Essentials (built into Win 8 apparently) and I removed the Toshiba Bluetooth. The built in Bluetooth drivers work at least well enough for my printer.
Got Windows 8 32bit working perfectly
Had some trouble with the
Intel Dynamic Power Performance Management driver (ETM) when I tried a clean install of Windows 8. The darn Setup file wouldn't execute giving me a compatibility error.
Then I ran into slow text input response only in the desktop version of IE 10. found out the Fujitsu TouchPad driver was making Internet Explorer go all spastic. So now I am on the lookout for an updated touchpad driver while I use the default ps/2 mouse driver that windows loaded.
Only way I found around the ETM driver was to install windows 7 pro, do not activate it, then install the ETM driver only, no other drivers or software, and then upgrade to windows 8 and install a few of the remaining drivers and software packages.
Hopefully someone out there will figure out a way to do a clean install of windows 8. It seems perfect for the touchscreen, even without the multitouch.
I have just done an upgrade from vista to win8 on a Mk1 and it all works great no driver issues at all
Welcome to the Toughbook forum
Thats good to know. Was the upgrade done on a CF-30 MK1 ?
