Not the same but will have to do
http://www.panasonic.com/business/tough ... puters.asp
It's Back.....new Toughbook Config Site
Re: It's Back.....new Toughbook Config Site
THANKS - As you say it is not the same but it will do. Better than nothing
Now I need to update my website link:)
Ken
Ken
CF-29E NKNXKM (Mk2) Ubuntu 10.10 Linux, Pentium M 1.3G LV (Centrino), 13.3Transmissive Touch XGA, 768MB, 40GB HD ,WLAN802.11b+g, WinXPP, Silicone Backlit KBD, Dual Connector, WWAN WIRELESS READY, Secured HDD/Battery doors
CF-29C WPCCKM (Mk1) Windows XP Pro ***HARTFORD ONLY***Pentium M 1.2GHz (Centrino), 13.3" Transmissive Touch Screen, 60GB HD, 1.5GB RAM, 56K Modem, FDD, Realtek 10/100 LAN, Verizon 1xRTT, Bluetooth, Silicone Backlit keyboard, WIN XPP, CD RW / DVD+- RW ROM, Floppy with LPT1 cable, Yellow tab main battery 7.65 AHr, MP extra battery 3.6 AHr, USB Delorme Earthmate LT-20 GPS, Kingston 120 VAC/12VDC car/aircraft 120 VA power supply
Motorola ML-900 - test machine -
Welcome to forum, if you need a hand we are here to help. Enjoy
The CF-18 and CF-29 will not work
The CF-19, 30, 50, 51, 52, 72, 73 and the 74 will work
These are only the ones I have checked so far
