Ribbon cable for OEM GPS on CF-18?
Does anyone have or know where I can find the wide ribbon cable to connect an OEM GPS module to the cf18 main board?
Re: Ribbon cable for OEM GPS on CF-18?
Your best bet would be Heardland but you would need the part # first. I will see if I can find the number later for you....at work now.
