Well I really wasn't getting any response on this elsewhere so I will start a thread on the new flagship Toughbook here
The Toughbook configuration tool has the new models now
Drivers are out on the .jp site for the mk-3’s as well
I downloaded and installed the conceal utility and it did not do anything on my mk-2, must be tied to the new hardware/motherboard that the mk-3 is using now
Comments ?
Alex
Info On The New Cf-30 mk-3
Re: Info On The New Cf-30 mk-3
LOL, Yea, I did that as well. Except I didn't do it on purpose.
Alex, I found this old thread and thought I would contribute since I have a MK3. The concealed mode is pretty neat. You set your preferences in the BIOS. That is the negative part of it, if you want to change them, which I do seem to do often, you of course have to reboot. I hate to reboot!
I remember after I 1st started using it all my lights and crap were off and I thought something was major wrong!
