CF-53 MK4 2nd LAN/Ethernet Port Install
Kam
#1 Post by Kam »
Hi,
I need to use 2 devices that connect via Ethernet simultaneously;
How do I install the Ethernet port & cable into the laptop ?
Kindly
Kam
Re: CF-53 MK4 2nd LAN/Ethernet Port Install
#2 Post by Rob »
You'd have to ship this into our config center to do this. Cannot be done aftermarket.
Can I please get the FULL model number of this unit? I will send an email to my POC's at Panasonic to see if they still have the parts to get this done.
ROB
Kam
#3 Post by Kam »
Rob wrote: Tue Jul 19, 2022 5:18 pm You'd have to ship this into our config center to do this. Cannot be done aftermarket.
ROB
Thanks ROB,
CF-537CL7NCM
Where is your config center located at ?
The processor of this unit is Intel i7 4600U,
Can it be upgraded with the i7 7600U ?
Regards
Kam
#4 Post by Rob »
CPU is a 3540M, not a 4600u. See below for factory desc:
Win7 (Win8.1 Pro COA) Intel Core i7-3540M 2.00GHz vPro 14.0" HD 500GB(7200rpm) 4GB Intel WiFi a/b/g/n/ac TPM Bluetooth Insertable Smartcard Emissive Backlit Keyboard No Absolute BIOS Multi-drive Toughbook Preferred
No, CPU is *NOT* upgradable, like 99.999% of the other laptops in this world, it's soldered on.
Our HQ facility is in Magnolia, TX - Rugged Depot. Let me email my rep to see if we can still do this. I'll know more by Monday as it's already 5:02PM on a Friday.
ROB
Kam
#5 Post by Kam »
Rob wrote: Fri Jul 22, 2022 3:02 pm CPU is a 3540M, not a 4600u. See below for factory desc:
ROB
Hi,
Nope, the laptop i have is i7 with 4600U "Haswell" processor
#6 Post by ADOR »
Does the model number on the sticker match the model number in the bios?
Kam
#7 Post by Kam »
Yes it does
#8 Post by Rob »
Got an answer today from my main POC at 8:23AM. He was out last week on vaca (Didn't send an auto-reply either).... Anyways his tech guy will be in tomorrow so I should have an answer on the 2nd LAN retrofit by COB tomorrow.
Kam
#9 Post by Kam »
Rob wrote: Mon Aug 01, 2022 1:55 pm Got an answer today from my main POC at 8:23AM. He was out last week on vaca (Didn't send an auto-reply either).... Anyways his tech guy will be in tomorrow so I should have an answer on the 2nd LAN retrofit by COB tomorrow.
Thank You Rob
#10 Post by Rob »
Okay,
They CANNOT do this I'm told. They don't have the parts any more :(
Sorry, I tried!!! I've sent a follow up email asking them if we can find the parts and send with it if they can do it. Will advise when they reply.
