CF-29 kernel config.
Michael AU
#1 Post by Michael AU »
HI all.
It's really good to be back among you. Here is a link to my github page for the kernel mod we come up with together. Feel free to use it on your CF-29s so that both card slots work on your machines.
I would like to create a specific kernel for the CF-29, and other models as well, so they run at the highest efficiency they can. This will take time and now the school year has started again time is limited again.
If I'm not working tomorrow I'll try to build a current Debian Bullseye kernel and if Rob lets me I'll upload it here for all to use.
Cheers.
Michael (Slarty Bartfast on FB)
CF-29 x 3 (Debian (Rugged) 11, FreeDOS 1.2, Windows 7)
CF-30 (Debian 11, Windows 10)
CF-31SBLAX1M (Debian 11, Windows 10)
CF-D1 (Debian 11, Windows 10, trying BlissOS)
Never give up, never surrender!
Re: CF-29 kernel config.
#2 Post by Rob »
Check out the other thread. Should be good for 1 gig. Is that big enough?
viewtopic.php?t=3507
#3 Post by ADOR »
Last time I ran linux on a Toughbook was when Ubuntu 10.10 came out, It ran great with out much headache, even dual booted it on my 29 with XP. I still keep a pendrive loaded with linux incase I need it.
Michael AU
#4 Post by Michael AU »
Rob wrote: Sun Feb 06, 2022 12:47 pm Check out the other thread. Should be good for 1 gig. Is that big enough?
That's plenty for the kernel thanks Rob.
Michael AU
#5 Post by Michael AU »
ADOR wrote: Sun Feb 06, 2022 7:33 pm Last time I ran linux on a Toughbook was when Ubuntu 10.10 came out, It ran great with out much headache, even dual booted it on my 29 with XP. I still keep a pendrive loaded with linux incase I need it.
Well I was , am, working on Rugged but life got extremely busy and my net connection sucked, infact it still does. I think the kernel is important so our hardware works properly for those of us who have multiple PCMCIA cards. Rugged will be built but any Debian Bullseye can run the kernel as it is built off Debian. Tweaking it further to make it smaller and totally modularised is quite tricky and I haven't got that bit working yet.
mklym
#6 Post by mklym »
Good to hear from you Michael.
I have been using the modded kernel you developed on my 29 since you first posted it. There have been zero issues. Thank you once again.
Michael AU
#7 Post by Michael AU »
Good to know mklym, thanks for the update.
