Threadlocker
Threadlocker
Does anybody know what threadlocker panasonic uses? It's a red one, maybe the Loctite 262?
Regards.
Re: Threadlocker
I think Loctite 262 Is red ? and a lot of Toughbooks I took apart is Blue in color.
Re: Threadlocker
The Air Force Toughbooks have blue locktite on them. And a LOT of it.
Factory Toughbooks have a small amount on the threads of certain screws. I have seen red(orange) and blue (NO, not purple).
Blue is standard grade and red is stronger and may require heat.
There are other grades of locktite. I have a penetrating grade that creeps into already tightened screws. (Green I think.)
I also have a light grade for plastics. (purple I think)
Re: Threadlocker
I found the red one removing the corner guards of a FZ-G1 and it was a piece of cake.
I'm going to try the red one on a new screw to see if it's so hard to remove. If Panasonic does it, so do I.
Regards.
