Any thoughts?
Here's is a a nice  page of ideas to start with.
https://www.makeuseof.com/tag/6-linux-d ... s-editors/
Fedora Design Suite sounds like a decent setup.
I know zip about Fedora.
							Linux distro for photography
						Re: Linux distro for photography
The OS itself should not be as much an issue as what access you have to the software. Try Mint in Cinn or xfce and add all the software you can. Or try one of these. https://distrowatch.com/table.php?distr ... untustudio
https://distrowatch.com/table.php?distribution=avlinux
Because in the end it's about what interface you are used to for the OS and then the programs you want to use. Good to see you Shawn.
				longknives
Have you looked into Darktable? It's listed as a Virtual lightable and darkroom for photographers.
http://www.darktable.org/
