Still running vista?
#1 Post by ADOR »
https://www.ghacks.net/2017/06/24/windo ... 8-updates/
Turns out there is a way to run server 2008 updates on your vista to keep it updated to 2020.
Ran across this looking for other stuff.
And if you missed it before there is a link in the article to where you can still get updates on xp till 2019.
Been wanting to try that on my 29. I just reloaded it back to xp sp2. It's just going to be used to load tuning software for the holley commander 950. I may try it on that system after I find out what updates NOT to install to keep MS out.
Re: Still running vista?
Nice find
#3 Post by toughasnails »
I tried clicking on the link but got nothing
#4 Post by ADOR »
I just tried it and it worked for me, try googling
Extend Windows Vista support by installing Windows Server 2008 updates
I know a lot won't get any use out of it, but maybe someone will.
