Screen replacement for CF-53 MK4
Anyone know where I can get some screen replacement for the CF-532JCZYCM? I'm in California.
Re: Screen replacement for CF-53 MK4
Yes I do know.
Our member Sadlmkr has several.
He is also located in Cali-forn-I-A.
CF-532JCZYCM
Status: CHANNEL LIMITED
MSRP: $1,409
Description: Lite, Windows 7 Professional (with Win 8.1 Pro COA), Intel Core i5‑4310U 2.0GHz, 14.0" HD LCD, 320GB Shock‑mounted (5400rpm), 4GB, Wi‑Fi, Bluetooth, DVD Super MULTI Drive, TPM 1.2, Lightweight Battery, Toughbook Preferred
CF-532JCZYCM
MSRP: $1,409
What trouble are you having with the screens? Non-operating or something else?
I no longer have any screens for the MK4.
Sorry for the late reply, but it has been crazy busy the past couple of weeks.
Sadlmkr, do you have part numbers for compatible non-touch screens for the MK4?
Did you try an external monitor?
Is your screen cracked or just black?
Your problem may not be your screen. It may be a bigger problem.
We have about 60-70 of these (mix of mk3s and mk4s) in the field at any given time, our field technicians would sometimes crack their screens either by dropping them and hitting the screen on something or slamming the screen with a pen on the keyboard.
I can get replacement screens for the mk3s easy enough through amazon or ebay but have had no luck sourcing screens for the mk4s.
Interesting.
I figured they all used the same LCD panel
I think they switched to the 30pin connectors from the 40pin ones. My eyesight is shot since I turned 40 so I didn't really count the pins but that's what it looks like they did.
