CF-19 MK4 CF-19VMRFX2M
Hi Guys,
still happy with my CF-30 but just got a CF-19 MK4 CF-19VMRFX2M. GPS is already installed but need to install a proper software and U-Block
I would like ton install a Gobi 2000 card but not sure which one to get under Rogers or Bell (canada).
Also, i'm looking to install a fingerprinit reader but just can't find the proper parts.
Which Bios is the most recent one on FTP.Panasonic.com??
CF-30 MK3, 1 Tb HDD, 4GB, GPS, Sierra Wireless Gobi2000, W7 Pro 32, Bluetooth, Emissive Keyboard, 3 batt,
CF-19 MK4, 1 Tb HDD, 4GB, GPS, Sierra Wireless Gobi2000 (planned), W7 Pro 32, Bluetooth, Emissive Keyboard, 3 batt,
Re: CF-19 MK4 CF-19VMRFX2M
I live in Canada but the price was way too high so I never did find out which card I needed...sorryWatchdogmp wrote:
I would like to install a Gobi 2000 card but not sure which one to get under Rogers or Bell (canada).
How's this one http://www.ebay.com/itm/GENUINE-Panason ... SwJb9WtL0KWatchdogmp wrote: Also, i'm looking to install a fingerprinit reader but just can't find the proper parts.
just not sure if its all there but here is another one that looks better
http://www.ebay.com/itm/GENUINE-Panason ... 2092018652
To buy the kit now is $365.00 new from Heartland Services (Panasonic)
That first one is missing the FFC. Very short cable that may be tough to find.
The second one looks complete.
http://www.ebay.com/itm/GENUINE-Panason ... SweW5VQW-F
Fingerprint readers are not bad to install in a CF19. They are tough to install in a CF30 or CF31.
Matt at Proton will not intentionally "do you wrong".
My opinion.
Nice avatar Shawn................
Jayburd
My opinion.
Jayburd
The newest listed for Mk4 is 4.0L11, my CF-19V is on 4.20L11. We have the same model infact.Watchdogmp wrote:Hi Guys,
Toughbook CF-19 Mk4
Toughbook CF-53 Mk4
Getac V110 G1
Thinkpad X1 Tablet
MacBook Pro 13
Toughbook CF-53 Mk4
Getac V110 G1
Thinkpad X1 Tablet
MacBook Pro 13
This model of Toughbook cf-19 has no wireless Lan, Bluetooth and its bracket. It is federal issue model.
You will need a half mini pcie wireless card(I believed an intel 6200 will be fine). Bluetooth module and its bracket. You can also installed a WWAN but you need to activate it by SPGOBI2K unlocker.
Hi Teo,
what do you mean it,s a federal issue? Mine was 110 Hrs only.
I ordered a 6205 wifi card.
For Bluetooth, I have installed it but not working. I think the cable is not going deep enough in the connector.
What is SPGOBI2k unlocker. Cant seem to find that on Google.
.teo wrote:This model of Toughbook cf-19 has no wireless Lan, Bluetooth and its bracket. It is federal issue model.
Teo is saying that the unit was originally setup and sold to a branch of the US federal government. Has nothing to do with the hours on the clock. The bluetooth might be locked out in the BIOS. I think I have the spgobi2k program. I will check later when I have time.
I have not dealt with a federal issued Toughbook so I can't say for sure, but you might have to flash the BIOS with a non-federal image to get all the wireless working.
Does this work? https://dl.dropboxusercontent.com/u/770 ... 62f92f.zipmklym wrote:Teo is saying that the unit was originally setup and sold to a branch of the US federal government. Has nothing to do with the hours on the clock. The bluetooth might be locked out in the BIOS. I think I have the spgobi2k program. I will check later when I have time.
Can you get into the BIOS?
Intel 6205 will not show up in the BIOS. You need a real 6200 to show up on a mk4. If wifi is already enabled in the BIOS, Windows will see the 6205 and it will work. Otherwise you need a 6200 card so you can go into the BIOS and enable the wifi.
I just did this 2 weeks ago.
Do you have the correct white flat cable for bluetooth? Is it installed the proper direction?
