After multiple crashes/re-boots after waking from Sleep, I ran WhoCrashed diagnostic on my CF-30 Mk 3 with Win 10 and it identified a driver error etmdrvmgr.sys, which is associated with Intel Dynamic Power Performance Management (DPPM). Since there is no updated Win 10 driver for Intel's DPPM should I just delete this file? Should I uninstall the etmservice.exe file (in Windows/System32) as well in order to delete the DPPM program? (There is no way to uninstall it via Control Panel as it's not listed.)
I don't want to remove anything that will prevent boot-up, but I don't know if this file or program is necessary. Any thoughts would be appreciated.
Thanks.
Intel Dynamic Power Performance Management -- NECESSARY?
Re: Intel Dynamic Power Performance Management -- NECESSARY?
But if you don't want to un-install you should be able to disable in services, then not to start at startup.
Thanks. I tried disabling it in the Services window but it did not solve the problem. The WhoCrashed program still identifies the etmdrvmgr.sys file as the culprit, even though the Intel DPPM program shows as Disabled in the Services window.
I'm not sure why a program that is disabled would still try to access its related .sys file. I also checked the Startup and Processes tabs in Task Manager and notice that the Intel DPPM program isn't listed there. Not sure where else to look at this point.
I wonder if I should try to uninstall the etmservice.exe file entirely and delete the etmdrvmgr.sys file... or maybe just rename the offending .sys file to etmdrvmgr.old and see what happens.
I appreciate the help in troubleshooting. Personally, I love my Toughbooks, and I'm glad to have a resource like this with folks who know a lot more than I do about these issues.
Just to add info to my previous post, here is the WhoCrashed entry. Am I correct that the etmdrvmgr.sys file is the offender? If so, is it okay to rename or delete it?
Thanks again for the help.
On Fri 4/1/2016 03:31:23 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\033116-26500-01.dmp
This was probably caused by the following module: etmdrvmgr.sys (EtmDrvMgr+0x19907)
Bugcheck code: 0x139 (0x3, 0xFFFFD0017D331610, 0xFFFFD0017D331568, 0x0)
Error: KERNEL_SECURITY_CHECK_FAILURE
file path: C:\WINDOWS\system32\drivers\etmdrvmgr.sys
product: Intel Dynamic Power Performance Management
company: Intel Corporation
description: Intel Dynamic Power Performance Management Driver
Bug check description: The kernel has detected the corruption of a critical data structure.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: etmdrvmgr.sys (Intel Dynamic Power Performance Management Driver, Intel Corporation).
Google query: Intel Corporation KERNEL_SECURITY_CHECK_FAILURE
Just to follow-up, I've pretty much exhausted all research avenues for this... I was told that deleting or changing the name of the etmdrvmgr.sys file could corrupt the OS and necessitate a complete reinstall. The only thing I haven't tried yet is running the Intel Dynamic Power Performance Manager (DPPM) program associated with this .sys file in Win 7 compatibility mode.
If that doesn't fix the issue then I guess it's back to a complete OS reinstall. Ugh.
From what I read years ago. (May not still apply. I bet it does).
Intel has power management utils that work really well. The PROBLEM is Microsoft did not trust that Intel knew what they were doing. So Microsoft wrote their own power management stuff. Microsofts stuff can conflict with Intels and cause issues.
Personally I would run the Intel stuff and let it disable the Microsoft crapola.
Shawn -- Thanks for the reply. But I'm not sure how to disable to Microsoft power management applications and only let the Intel apps run.
Additionally, I did run a Bug check analysis, which showed the following info. I think it confirms a problem with the etmdrvmgr.sys driver, but I don't know how to fix it. Any additional suggestions from the forum experts would be welcome. Thanks.
Microsoft (R) Windows Debugger Version 10.0.10586.567 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\041316-31015-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 10586 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 10586.162.amd64fre.th2_release_sec.160223-1728
Machine Name:
Kernel base = 0xfffff801`54a75000 PsLoadedModuleList = 0xfffff801`54d53cd0
Debug session time: Wed Apr 13 10:04:55.669 2016 (UTC - 4:00)
System Uptime: 0 days 0:13:25.492
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 139, {3, ffffd0004888c610, ffffd0004888c568, 0}
*** WARNING: Unable to verify timestamp for EtmDrvMgr.sys
*** ERROR: Module load completed but symbols could not be loaded for EtmDrvMgr.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : EtmDrvMgr.sys ( EtmDrvMgr+19907 )
Followup: MachineOwner
1: kd> !analyze -v
KERNEL_SECURITY_CHECK_FAILURE (139)
A kernel component has corrupted a critical data structure. The corruption
could potentially allow a malicious user to gain control of this machine.
Arguments:
Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove).
Arg2: ffffd0004888c610, Address of the trap frame for the exception that caused the bugcheck
Arg3: ffffd0004888c568, Address of the exception record for the exception that caused the bugcheck
Arg4: 0000000000000000, Reserved
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10586.162.amd64fre.th2_release_sec.160223-1728
SYSTEM_MANUFACTURER: Panasonic Corporation
SYSTEM_PRODUCT_NAME: CF-30KCP512B
SYSTEM_SKU: CF-30KCP512B
SYSTEM_VERSION: 003
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: V3.01L23
BIOS_DATE: 10/08/2009
BASEBOARD_MANUFACTURER: Panasonic Corporation
BASEBOARD_PRODUCT: CF30-3
BASEBOARD_VERSION: 1
DUMP_TYPE: 2
BUGCHECK_P1: 3
BUGCHECK_P2: ffffd0004888c610
BUGCHECK_P3: ffffd0004888c568
BUGCHECK_P4: 0
TRAP_FRAME: ffffd0004888c610 -- (.trap 0xffffd0004888c610)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffe000f190f3d0 rbx=0000000000000000 rcx=0000000000000003
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80154be86d6 rsp=ffffd0004888c7a0 rbp=0000000000000000
r8=0000000000000001 r9=0000000000000000 r10=00000000000005eb
r11=ffffe000f21daeb0 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz na pe nc
nt! ?? ::FNODOBFM::`string'+0x225d6:
fffff801`54be86d6 cd29 int 29h
Resetting default scope
EXCEPTION_RECORD: ffffd0004888c568 -- (.exr 0xffffd0004888c568)
ExceptionAddress: fffff80154be86d6 (nt! ?? ::FNODOBFM::`string'+0x00000000000225d6)
ExceptionCode: c0000409 (Security check failure or stack buffer overrun)
ExceptionFlags: 00000001
NumberParameters: 1
Parameter[0]: 0000000000000003
Subcode: 0x3 FAST_FAIL_CORRUPT_LIST_ENTRY
CPU_COUNT: 2
CPU_MHZ: 63c
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 17
CPU_STEPPING: a
CPU_MICROCODE: 6,17,a,0 (F,M,S,R) SIG: A0C'00000000 (cache) A0C'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: LIST_ENTRY_CORRUPT
BUGCHECK_STR: 0x139
PROCESS_NAME: System
CURRENT_IRQL: 2
ERROR_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_CODE_STR: c0000409
EXCEPTION_PARAMETER1: 0000000000000003
ANALYSIS_SESSION_HOST: ADMIN-PC
ANALYSIS_SESSION_TIME: 04-13-2016 10:12:56.0149
ANALYSIS_VERSION: 10.0.10586.567 x86fre
LAST_CONTROL_TRANSFER: from fffff80154bc22e9 to fffff80154bb7760
STACK_TEXT:
ffffd000`4888c2e8 fffff801`54bc22e9 : 00000000`00000139 00000000`00000003 ffffd000`4888c610 ffffd000`4888c568 : nt!KeBugCheckEx
ffffd000`4888c2f0 fffff801`54bc2610 : ffffe000`f1cd4338 ffffe000`f1cd4338 ffffe000`00000080 ffffe000`f1ccd7c0 : nt!KiBugCheckDispatch+0x69
ffffd000`4888c430 fffff801`54bc17f3 : ffffe000`f1c598a0 ffffe000`f16ba150 00000000`00000040 00000000`00000000 : nt!KiFastFailDispatch+0xd0
ffffd000`4888c610 fffff801`54be86d6 : 00000000`00000000 ffffd000`4888c830 ffffe000`f2d3f440 00000000`000007ff : nt!KiRaiseSecurityCheckFailure+0xf3
ffffd000`4888c7a0 fffff801`54af19bc : ffffe000`f190f398 fffff800`00000000 00000000`00000000 ffffe000`f164a490 : nt! ?? ::FNODOBFM::`string'+0x225d6
ffffd000`4888c810 fffff800`e9519907 : 00000000`00000005 00000000`00000000 ffffe000`f1659880 ffffe000`f16532d0 : nt!KeSetEvent+0xfc
ffffd000`4888c8a0 00000000`00000005 : 00000000`00000000 ffffe000`f1659880 ffffe000`f16532d0 00000000`00000001 : EtmDrvMgr+0x19907
ffffd000`4888c8a8 00000000`00000000 : ffffe000`f1659880 ffffe000`f16532d0 00000000`00000001 ffffd000`4888c930 : 0x5
STACK_COMMAND: kb
THREAD_SHA1_HASH_MOD_FUNC: 7c47dc770db2b9a3c5d99104930644e45d9f7a89
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 68387bd5aa52b5cdc689cdddd4d411cbf2975c0d
THREAD_SHA1_HASH_MOD: 9b617c6f1e4cb0265f0e4eb5857d12daf221e9a8
FOLLOWUP_IP:
EtmDrvMgr+19907
fffff800`e9519907 ?? ???
SYMBOL_STACK_INDEX: 6
SYMBOL_NAME: EtmDrvMgr+19907
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: EtmDrvMgr
IMAGE_NAME: EtmDrvMgr.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4d4374b7
BUCKET_ID_FUNC_OFFSET: 19907
FAILURE_BUCKET_ID: 0x139_3_EtmDrvMgr!Unknown_Function
PRIMARY_PROBLEM_CLASS: 0x139_3_EtmDrvMgr!Unknown_Function
TARGET_TIME: 2016-04-13T14:04:55.000Z
OSBUILD: 10586
OSSERVICEPACK: 0
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2016-02-24 00:48:00
BUILDDATESTAMP_STR: 160223-1728
BUILDLAB_STR: th2_release_sec
BUILDOSVER_STR: 10.0.10586.162.amd64fre.th2_release_sec.160223-1728
ANALYSIS_SESSION_ELAPSED_TIME: 5aa3
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x139_3_etmdrvmgr!unknown_function
FAILURE_ID_HASH: {70061d8d-96ef-6b24-fe58-e171301e806e}
Machine Name:
1: kd> !analyze -v
Arguments:
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
SYSTEM_VERSION: 003
DUMP_TYPE: 2
BUGCHECK_P1: 3
BUGCHECK_P4: 0
NumberParameters: 1
CPU_COUNT: 2
CPU_MHZ: 63c
CPU_FAMILY: 6
CPU_MODEL: 17
CPU_STEPPING: a
BUGCHECK_STR: 0x139
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
EtmDrvMgr+19907
OSBUILD: 10586
OSSERVICEPACK: 0
OS_REVISION: 0
SUITE_MASK: 272
PRODUCT_TYPE: 1
OSNAME: Windows 10
OS_LOCALE:
USER_LCID: 0
ANALYSIS_SOURCE: KM
Reinstall windows over the old version.
It will save all of your old stuff and repair any missing or corrupt drivers.
