- Wifi does not connect through Network Manager, it continuously asks for my password
 Hangs up on restart, I have to physically do a hard shut down.
 Touch pad is EXTREMELY slow, and the mouse is operates on crack speed with a side of meth and triple clicks EVERYTHING
 No Sound.
~ $ inxi -Fxz
System:    Host: WolfPack7 Kernel: 3.19.0-32-generic i686 (32 bit gcc: 4.8.2)
           Desktop: MATE 1.12.0 (Gtk 3.10.8~8+qiana) Distro: Linux Mint 17.3 Rosa
Machine:   System: Matsushita product: CF-29NTQGZBM v: 005
           Mobo: Matsushita model: CF29-5 v: 001 Bios: Phoenix K.K. v: V5.00L14 date: 08/03/2006
CPU:       Single core Intel Pentium M (-UP-) cache: 2048 KB
           flags: (nx pae sse sse2) bmips: 3191 speed: 1600 MHz (max)
Graphics:  Card: Intel Mobile 915GM/GMS/910GML Express Graphics Controller bus-ID: 00:02.0
           Display Server: X.Org 1.17.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1024x768@60.0hz
           GLX Renderer: Mesa DRI Intel 915GM x86/MMX/SSE2 GLX Version: 1.4 Mesa 10.5.9 Direct Rendering: Yes
Audio:     Card Intel 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller
           driver: snd_intel8x0 ports: 1c00 18c0 bus-ID: 00:1e.2
           Sound: Advanced Linux Sound Architecture v: k3.19.0-32-generic
Network:   Card-1: Marvell 88E8053 PCI-E Gigabit Ethernet Controller
           driver: sky2 v: 1.30 port: 3000 bus-ID: 02:00.0
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
           Card-2: Intel PRO/Wireless 2915ABG [Calexico2] Network Connection
           driver: ipw2200 v: 1.2.2kmprq bus-ID: 06:02.0
           IF: eth1 state: dormant mac: <filter>
Drives:    HDD Total Size: 60.0GB (10.8% used) ID-1: /dev/sda model: TOSHIBA_MK6021GA size: 60.0GB
Partition: ID-1: / size: 54G used: 4.6G (10%) fs: ext4 dev: /dev/dm-1
           ID-2: /boot size: 236M used: 47M (21%) fs: ext2 dev: /dev/sda1
           ID-3: swap-1 size: 1.60GB used: 0.00GB (0%) fs: swap dev: /dev/dm-2
RAID:      No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors:   System Temperatures: cpu: 57.8C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 144 Uptime: 43 min Memory: 385.7/1499.1MB Init: Upstart runlevel: 2 Gcc sys: 4.8.4
           Client: Shell (bash 4.3.111) inxi: 2.2.28
~ $ ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:0b:97:b8:e2:69
          inet addr:192.168.1.108  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::20b:97ff:feb8:e269/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:15766 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10035 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:14744082 (14.7 MB)  TX bytes:1294154 (1.2 MB)
          Interrupt:16
eth1      Link encap:Ethernet  HWaddr 00:16:6f:be:8c:8b
          inet6 addr: fe80::216:6fff:febe:8c8b/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:28 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:4786 (4.7 KB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:724 errors:0 dropped:0 overruns:0 frame:0
          TX packets:724 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:124448 (124.4 KB)  TX bytes:124448 (124.4 KB)Code: Select all
$ sudo lshw -c network
[sudo] password for :
  *-network
       description: Ethernet interface
       product: 88E8053 PCI-E Gigabit Ethernet Controller
       vendor: Marvell Technology Group Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 19
       serial: 00:0b:97:b8:e2:69
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm vpd msi pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=192.168.1.108 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:25 memory:b4000000-b4003fff ioport:3000(size=256) memory:b4020000-b403ffff
  *-network
       description: Wireless interface
       product: PRO/Wireless 2915ABG [Calexico2] Network Connection
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:06:02.0
       logical name: eth1
       version: 05
       serial: 00:16:6f:be:8c:8b
       width: 32 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ipw2200 driverversion=1.2.2kmprq firmware=ABG:9.0.5.27 (Dec 12 2007) latency=32 link=no maxlatency=24 mingnt=3 multicast=yes wireless=IEEE 802.11abg
       resources: irq:18 memory:b8003000-b8003fff
 ~ $ dmesg | grep -e ipw -e eth1
[  102.932486] libipw: 802.11 data/management/control stack, git-1.1.13
[  102.932493] libipw: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
[  103.171076] ipw2200: Intel(R) PRO/Wireless 2200/2915 Network Driver, 1.2.2kmprq
[  103.171083] ipw2200: Copyright(c) 2003-2006 Intel Corporation
[  103.237498] ipw2200: Detected Intel PRO/Wireless 2915ABG Network Connection
[  103.827363] ipw2200: Detected geography ZZA (11 802.11bg channels, 13 802.11a channels)Code: Select all
~ $ rfkill list
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: noCode: Select all
~ $ ls -l /lib/firmware | grep ipw
-rw-r--r--  1 root root  209190 Aug 26  2015 ipw2100-1.3.fw
-rw-r--r--  1 root root  201138 Aug 26  2015 ipw2100-1.3-i.fw
-rw-r--r--  1 root root  196458 Aug 26  2015 ipw2100-1.3-p.fw
-rw-r--r--  1 root root  191154 Aug 26  2015 ipw2200-bss.fw
-rw-r--r--  1 root root  185428 Aug 26  2015 ipw2200-ibss.fw
-rw-r--r--  1 root root  187836 Aug 26  2015 ipw2200-sniffer.fw
 $ iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
eth1      IEEE 802.11abg  ESSID:off/any
          Mode:Managed  Frequency:2.437 GHz  Access Point: Not-Associated
          Bit Rate:0 kb/s   Tx-Power=20 dBm   Sensitivity=8/0
          Retry limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0I have battling this for a week now. Any help would be appreciated.
AR
