CF30 Mk3 RAM upgrade
my Mk3 is running Win7 Pro 64, is there any advantage to be gained by increasing the memory to 8gb (or more?)
Panasonic Toughbook
CF-30KTPAX2M
Win7 Pro 32bit
160gb/4gb
Gobi2k WWAN&GPS
Intel 5300 WLAN
Sony Optiarc AD5540 Optical
More goodies to come
CF-30KTPAX2M
Win7 Pro 32bit
160gb/4gb
Gobi2k WWAN&GPS
Intel 5300 WLAN
Re: CF30 Mk3 RAM upgrade
You're not going to be able to put 8GB in that I don't think...
I could be wrong but I'm pretty sure it's 4GB max (2x2gb)
thats what I was wondering...... I dont know if its a physical limitation of the motherboard/bios, or if its a OS thing, I've seen mention that 64 bit versions of windows 7 are better with 8gb or more
Panasonic Toughbook
CF-30KTPAX2M
Win7 Pro 32bit
160gb/4gb
Gobi2k WWAN&GPS
Intel 5300 WLAN
CF-30KTPAX2M
Win7 Pro 32bit
160gb/4gb
Gobi2k WWAN&GPS
Intel 5300 WLAN
Nothing to do whatsoever with the OS
All on the chipset.
All on the chipset.
I had 8GB in my CF-30 Mk2, running Ubuntu x64 and Win7 Ultimate x64.
I ordered (2X4GB) SODIMM 667MHz 200-Pin PC2-5300 DDR2 1.8V Low Density 16 CHIP, Notebook memory modules and they worked fine.
I like a lot of RAM...
