hello every one .
i just got a cf-29ctpgzkm
and i am learning the hard way , i bought a hdd for my 29 as its a project and it has a caddy but i found the ribbon torn , and it doesnt seam to fit but maybe its all i need
the links here are the hdd i bought and the ribbon i have got in the caddy but there is more pins on the hdd than the plug on the ribbon and whats the extra plug for ?
http://www.ebay.co.uk/itm/301794395285? ... EBIDX%3AIT
http://www.ebay.co.uk/itm/262009744671? ... EBIDX%3AIT
the second thin i want is a cd drive. but no idea what i should get plus
i think i figured out i need ddr1 not ddr2 as my ddr2 didnt fit but it has nothing in the slot to compare with
any help would be great .
cf29 hdd adapter ribbon
Re: cf29 hdd adapter ribbon
Send Jeff a Private message. He has quite a selection of CF29 parts.
http://www.toughbooktalk.com/memberlist ... ile&u=1074
Look...you hit me at a good time. PM me and I will send you a complete caddy and/or a CF-29 Mk1 with spare caddy.. No cheat...I have them (4) For what they are worth to you.
Read my signature below.
Otherwise NO is better than messing about with two weeks of PM's.
MK1 is a good unit. The touchscreens are tougher than MK 2-5. Not fast but a rugged unit, built to last.
FYI....I will NOT check back here. Too many irons in the fire. So PM. Offers good CONUS or elsewhere. You pay shipping.
72 hours from now I will forget this.
