Does the CF-31 HDMI carry sound?
Does anyone know. If so, is there some way that you must configure it for output?
Re: Does the CF-31 HDMI carry sound?
from the reference manual
External Display 54
Windows7
1 Click (Start) - [Control Panel] - [Hardware and Sound] - [Sound Playback].
2 Select the sound output destination.
3 Click [Set Default], and then click [OK].
External Display 54
Windows7
Yes sir!
Thanks guys, now all I have to do is Figure it out in Linux. Just knowing that the sound is there, helps!
Doh! I found the setting to direct sound through the HDMI Port, in of all places, SOUND! Really, I must have looked here a dozen times; I am not sure how I missed it!
Now I have a discarded 55" Plazma as a second monitor in my office at at the work site. It works great as a stereo, for Internet Programming and of course DVD's. Anyone found a BluRay that will work with the CF-31?
I have one in mine.
Both of these work. The Hp seemed finicky once in a while booting certain disks. Could have easily been my disk..
BD-ROM
Sony Optiarc..BC-5500H
BLuRay Burner
HP BT20N
BD-ROM
BLuRay Burner
HP BT20N
Thanks Shawn! Time to hit eBay!Shawn wrote:I have one in mine.
BD-ROM
BLuRay Burner
HP BT20N
OK, I ordered the newer Sony BC-5550H SATA 12.7MM Blu-ray Combo Optiarc Drive for $41. Now I just have to hope that it works!
No, this is a Blu-Ray DVD Player, you are thinking of records...Shawn wrote:Groovy
