Win7 x64 driver that works with hot keys
Azrial
#1 Post by Azrial »
I forget, which Video Driver works with the hotkeys under Win7x64? I thought that I had all of them I used last time saved, but... :pat:
I have tried a dozen, and still, no luck. I even tired the one that I see referenced on the CF-30 Win7x64 Wiki, but that failed to work as well.
Any idea?
UNCNDL1
Re: Win7 x64 driver that works with hot keys
#2 Post by UNCNDL1 »
This post references a 32 and 64 bit restore option from Heartland:
http://www.toughbooktalk.com/viewtopic.php?f=28&t=2605
Might be work checking out...
Azrial
#3 Post by Azrial »
UNCNDL1 wrote:This post references a 32 and 64 bit restore option from Heartland:
LoL, thanks, but I am not interested in a x86 machine. I would not have went to 8GB of RAM if I was. I find x64 runs faster, particularly with multiple programs running and of course gives me more working memory.
Besides, this problem was solved when I sold my CF-30! But thanks for the thought!
But, for those that kind this post in the far far future, there is a driver that will give you hotkey support of both sound and video brightness, I have used it before. :D
UNCNDL1
#4 Post by UNCNDL1 »
Sorry Bill, the link references a 64 bit option via the restore image, I thought It might have worked for you too...
Maybe this is a better reference:
http://es.pcdrivers.guru/panasonic-toug ... html#sos27
Scroll down, it's there
Azrial
#5 Post by Azrial »
Thanks a lot! I will take a detailed look later. There looks to be several there for Win7x64!
UNCNDL1
#6 Post by UNCNDL1 »
Any headway on this issue for you?
Azrial
#7 Post by Azrial »
UNCNDL1 wrote:Any headway on this issue for you?
No Sir, I am going to point my buyer to it. I no longer have a CF-30 to play with. I am getting ready to do some VooDoo on the new CF-31 though. : )
Thanks for your help!!!
