CF-19 time!!!!!!
Bill_TN
CF-19 time!!!!!!
#1 Post by Bill_TN »
:pbjt: :pbjt: :pbjt: :pbjt: :pbjt: :pbjt: :pbjt:
Bill just got new TOYS!!!!
Bill gonna go have fun now. Thank you Paul. :D
Bill_TN
Re: CF-19 time!!!!!!
#2 Post by Bill_TN »
Hey. I know I saw it in here. But can't find it now. Link to a cf-19 manual/service manual. Thinking that to change both ram I have to pull the bottom. Taking it to 4 gb. Gone surfing again.
#3 Post by toughasnails »
What is the full model number of your new toy so I can send you the service manual
#4 Post by ADOR »
He got a Mk1 and Mk2 from me in trade. The Mk2 is a good standard unit, the Mk1 I am not sure if the touch works but everything else does. The Mk1 will make a good bump around unit.
http://www.tim.id.au/blog/tims-laptop-s ... -panasonic
Bill_TN
#5 Post by Bill_TN »
And thank you Toughasnails, with the early morning arrival of that info, I've already started playing.
:pbjt:
Bumped the ram in the mk 2 to 3gb added 120gb hdd dropped mint cinn in it and building from there.
The mk1 seems to have one of those funny pressure star shaped glare in the middle of the screen. Looks like if one was pushing on screen. But since theres no marks on front might be from backside. No problem, SURGERYYYYYYYYYYYYY!!!!! Plan to open it up and check for pressure from cover and any FOD that may be in there. Seen it before on Dell type stuff. Not worried at all. Heck I'm over joyed. I have new toys. CF 51's and cf 19's and cf 29 and only santa knows what the heck else will come rolling in the door next. :blob:
Bill_TN
#6 Post by Bill_TN »
Bummed. Just figured out that my digitizer pen is missing it's button. @ 40+ dollars on fleabay I'll just work around that for awhile. LOL.
#7 Post by Shawn »
This will function properly for $3.29...It won't fit in the little holder, unless you drill out the plastic insert inside the lid.
SAMSUNG GALAXY NOTE 2 N7100 I317 T889 N7105 TOUCH STYLUS S PEN
http://www.ebay.com/itm/311262161301?_t ... EBIDX%3AIT
#8 Post by ADOR »
I was thinking both of the ones I sent you were touch, not digitizer?
If one is digitizer
Same as Wacom M200 will fit the digitizer slot, but no hole for the tether.
Also with out the tether hole is this PA3317U-2ETC Toshiba pen
These fit in the holder, I have some digitizer pens if I would of realized one was digitizer I would of put one in it.
To be safe put up the model numbers.
Bill_TN
#9 Post by Bill_TN »
Nope Ador, both that I got from you are touch. I got this little gem in another trade. :D So far trading has caused my T/B collection to multiply quite well. :boing: :clapping:
#10 Post by ADOR »
That is prone to happen here, lol.
