CF27 handle
CF27 handle
#1 Post by Shawn »
Rob did this a while back. I copied his idea and added to it..
Here's a photo of the handle swap before I added my mod..
Here it is after my mod..Now I can see the charging LED..
mklym
Re: CF27 handle
#2 Post by mklym »
Nice job Shawn.
Re: CF27 handle
#3 Post by Shawn »
Thanks Morgan...
I really missed having the charging LED.
Re: CF27 handle
#4 Post by ADOR »
Is there enough "meat" on the handle to make a pass though hole for the headphone jack? The diameter of the hole needed may be too much.
Re: CF27 handle
#5 Post by Shawn »
I think there is enough.
It looks like the headphone jack hole would be almost centered between that metal edge and the plastic insert.
In a couple days I will try to drill a hole for the headphones.
I'll need to get my battery drill and bits from work....It may end up being several weeks before I actually remember..:)
I'll probably need a 5/16 hole...maybe even 3/8...
I do have a couple extra handles so I can afford to experiment on one.
Re: CF27 handle
#6 Post by ADOR »
I wasn't saying do it,lol, just curious. I got a spare 27 handle, but just haven't mounted it on anything yet.
Re: CF27 handle
#7 Post by Shawn »
I was considering it anyway.....eventually I would have drilled the hole...
Re: CF27 handle
#8 Post by Shawn »
I did not realize our mistake until I was done with the passthru hole..
You said headphone jack, but the headphone jack is not covered, It's the microphone jack that WAS covered.
It turned out well. I am pleased...
It is all black. The handle is slightly smoother and for some reason it came out blue in the photo.
Re: CF27 handle
#9 Post by toughasnails »
Very good job I must say :clapping:
