intel 5100 wlan card and a broadcom 11g card
I had a friend give me (2) intel 5100 11n cards and a broadcom 11g (not sure of the number have to check when I get home from work). not sure if these are good wlan card or not. I figured i would offer them on here if they work, I do not need them as I am getting an sr71 to put in my cf-30. not sure if they are worth it but I am looking for a gps kit for either my cf-30 for cf-19, I would trade all 3 of these for one kit (probably not worth it but figured I would try).
CF-19KHRAX2M upgraded to 4gb ram and 128gb ssd, adding gps.
CF-30FASEZAM upgraded to 4gb ram, sr71 wlan and 128gb ssd, adding gps
Re: intel 5100 wlan card and a broadcom 11g card
The buy sell trade forum would be a better place for this..
Blair, Do you want to move this?
What is the full model number of your CF30?
that is the model number of cf-30, that is what is one the tag on the bottom. I am not looking to sell these, just want them to go to a good home, not worth the hassle of sleezebay.
The truth is the cards can be bought on ebay for $4.50 shipped to my door. My guess that is why your friend gave them to you. GPS is $99.99 and up
Are they full size or half size?
Did they come from a Hp or a Lenovo?
Full size and not from Hp or Lenovo and I could use the 5100's
I am guessing half size, these thing are tiny about 2" or so square. Came from dell laptop, not sure what model #
Dell is ok.....Half size will need an adapter thingy....
I'll take them if you want to send them my way....
I can PM you..
I can PM you..
