Android on ToughBook
glitch
#1 Post by glitch »
OK, so I tried to runAndroid-x86 on a CF-29 Mk1.
Using a Android-x84 4.4-r2 Install / Live CD. Black screen and a prompt under live. I couldnt get anything to run.
I tried a different iso that I had a few weeks ago, I tried to install it, ran for a long time looking for Android image but never booted to a black screen with a prompt or a gui.
Any idea what I am doing wrong?
glitch
Re: Android on ToughBook
#2 Post by SHEEPMAN! »
Screen driver?
Can you add drivers to the LiveCD?
I will not be distracted....nooooooo......:)
With the MK1 you can boot USB with a Plop floppy or cd. Wrote this then found this:
http://www.murga-linux.com/puppy/viewto ... 65449eb9f2 noooooo!
glitch
#3 Post by glitch »
Its not a command line interface is what I mean, but that was the old iso, this Android 4.4-r2 gets to the command prompt but then stops.
If it was linux I would think the xorg wasnt running. I will do some research and see what I can come up with. It may take a few days.
glitch
Mxx20
#4 Post by Mxx20 »
I know it works in vm, I've had it running on my C1....it's fun to tinker with, I've always wanted to load in justthat andsee how it does
#5 Post by Shawn »
Do a search for ice cream shell for Linux. It makes Linux "look" like Android.
Not the same I know..It's like the Pear distro. Looks like OS X but doesn't operate like it.
#6 Post by Rob »
Why not just get a B1, B2 or A1? :P
#7 Post by Shawn »
Does Panasonic offer a Android CF52? :rofl:
#8 Post by ADOR »
Rob wrote:Why not just get a B1, B2 or A1? :P
Because if you set it up right you can triple boot between windows, Linux and Android, lol.
I haven't keep up with the X86 android project like I use too. Have had too much stuff going on here lately. But the last one I ran was a 2.2/2.3 on a T5. It took a little tweaking to get it all to run right. I think I booted a version of 3 on it also but didn't get around to finishing it up.
If you just want quick emulation you can use bluestacks.
#9 Post by Shawn »
Triple boot? :pat:
That just sounds like a bad idea from the go...Something 30 years ago I would have thought was brilliant in the middle of a two day drunk. :cheers:
After spending a week trying to set up a triple boot, I would be BEGGING someone to hit me in the head with a large hammer just to make the pain STOP.
Paul, you forgot OS X..QUAD boot anyone?... :rofl:
I know you kidding.
If I was bored enough, it would be quite a challenge to make a quad boot. Maybe this CF 52 Mac with no wifi. Only issue is OS x doesnt play well with others.
#10 Post by ADOR »
Actually it was easy if you set up windows first, then let grub take care of the rest. I had 10.10 installed like it was a program in windows so it worked separately, but was all on the same partition.
