U1 schematic
Post all questions and information about the CF-U1, H1, & H2 in here.
U1 schematic
#1 Post by Shawn »
Do we have any schematics?
Do we have any info on internal usb ports?
Info on aftermarket GPS?
Too busy and forgetful to search at the moment..
Re: U1 schematic
#2 Post by toughasnails »
Nope, just checked and we have none. Someone was looking into GPS...Paul maybe?
Re: U1 schematic
#3 Post by Shawn »
Sounds familiar..
Re: U1 schematic
#4 Post by ADOR »
Two of my units have GPS. If I remember right Springfield used a CF-19 GPS in a U1. Also there is a separate daughter board for the U1 WWAN card. So that give you another slot connector. If I can get the Mk1 to Mk2 swap done this time home I should have lots of pictures.
http://www.custom-toughbooks.com/index. ... cts_id=195
A few shots of the inside.
I got more links, the internet is slow on the rig tonight, Maybe in the morning they will come up.
Re: U1 schematic
#5 Post by Shawn »
Paul,
Thanks, that's a big help...It does look like a CF19 unit may work....
Re: U1 schematic
#6 Post by ADOR »
Here is a couple of more shots.
There appears to be a fan/fanless U1 versions.
Re: U1 schematic
#7 Post by Shawn »
By the looks of the photos from custom Toughbooks, it looks like he uses the same module as a CF 19
Return to “CF-U1 / CF-H1 / CF-H2 Ultra Mobile Rugged Talk (Discontinued Models)”
