Wrong Recoevery DVD's?
swingy
#1 Post by swingy »
Hi, I am trying to recovery my CF-19CHBAXBM the recovery DVD I have is DFQM8447MA WIN XP SP2 Tablet edition. I am pretty sure I have the Tablet/digitizer screen as it has the stylus.
Every time I run the DVD I get a message saying this model is not supported. Do I have the wrong Disc?
I did modify the batch file to something like this which I found on another forum -
PROMPT $P$G
rem -------------------------------
rem RCV_OS check (as HD recovery)
:PRECHKAC
if "%RCV_OS%" == "XP_PRO" etc, etc, etc....
I do get further into the recovery process -
After setting the Toughbook to boot from the CD Drive (see above), reboot the Toughbook with the Panasonic recovery disk in the CD drive.
2.Press 1 to execute Recovery. The License Agreement screen appears.
3.Press 1 to select "Yes, I agree to the provisions above and wish to continue."
4.Select the installation settings.
5.At the confirmation message, press Y. Reinstallation starts automatically.
At this stage the message I get on screen is -
An Error has Occurred.
I have also fdisk'd the MBR and made a new partition....
Thanks Ben
Re: Wrong Recoevery DVD's?
Model Number:CF-19CHBAXBM
Status DISCONTINUED
MSRP:$3,599
Description: WinXP, Intel Core Duo U2400 1.06GHz (Centrino), 10.4" XGA Touch, 80GB, 512MB, Intel WiFi a/b/g/n, Dual Pass (UpperWWAN/Lower:WLAN), TPM, Bluetooth, No Drive
a CF19 C is a mk1..Touchscreen
You need this disk..
MK1-XP2M-TSW
DFQX4054LA
Windows XP
swingy
#3 Post by swingy »
Mm, so why do I have a stylus?
Also given those details I take it I will have the wrong DVD's?
#4 Post by Shawn »
Touchscreens have stylus's also
MK1-XP2M-TSW
DFQX4054LA
Windows XP
swingy
#5 Post by swingy »
Kool, I'll try to get hold of that one. Thanks Shawn.
Ben
#6 Post by ADOR »
The smaller hole is for touch stylus, wider hole is for the digitizer stylus.
The digitizer stylus has a clicker button on the side.
The standard one is just plastic.
Also what does your COA say? Tablet or Pro?
swingy
#7 Post by swingy »
Hi ADOR,
The COA has PRO.
I did ask the seller before I bought the DVD's also gave him model and serial.....ohh well another Frisbee!
Ben
#8 Post by ADOR »
Pro equals XP pro not tablet. It can always be resold.
#9 Post by Springfield »
swingy wrote:I did ask the seller before I bought the DVD's also gave him model and serial....
Well now that you know, maybe the seller has the right ones and will swap for what he sent. Who did you get them from?
swingy
#10 Post by swingy »
Bought from ebay, hopefully he has the right one.
Ben
