SolydXK and the CF-50
safn1949
#1 Post by safn1949 »
So tell me what I'm doing wrong here,I install SolydXK and all goes well till the end,it asked me if I wanted to restart and use it.I did ,it did and PXE-E61 Media test failure. So thinking I may have removed the disc too early I reinstall.
But this time I say no,wait till it shows the desktop and shut down,restart to F2,remove disc and check boot order,F10 enter same *$&#^$*$) thing. I freely admit I have no idea. :confused:
Re: SolydXK and the CF-50
#2 Post by SHEEPMAN! »
Boot the live cd. Does it see the hard drive? From desktop home directory.
safn1949
#3 Post by safn1949 »
This is what I have,it's a 40gb drive.
#4 Post by SHEEPMAN! »
Is this a dual/triple quad boot or something?
Looks like you have duplicates ....consider wiping the disk. I tried to find a 32 bit live cd but no luck so far.
I think there is an option in downloading for gpart. delete all the lines, follow instructions to wipe them and then back up a page and mark the hopefully single line with a right click and /.
Some people use a separate home directory partition. It just confuses me so I ignore it. You can always save your home directory if needed.
Good luck,
safn1949
#5 Post by safn1949 »
Beats me,but I'll give it a shot.
safn1949
#6 Post by safn1949 »
Here is what I get when I try to make the partition. These are 40gb drives I bought the other day,I have loaded Windows 2000 to them but when I try Linux I get this error.
UNCNDL1
#7 Post by UNCNDL1 »
I'm not sure what system you are using, but suggest you use a more user friendly linex distribution.
I would try Zorin 9 Lite first and go from there:
http://zorin-os.com/free.html
#8 Post by SHEEPMAN! »
That's odd. :D Brilliant minds think alike.
I haven't checked in for a couple hours because I was dumping Solydx for Zorin.
It's was on a ssd and wouldn't play with trim.
CF-29 MK5
safn1949
#9 Post by safn1949 »
I don't think it will boot on the pentium M because of pae. I have a copy i can try,it did the same thing with crunchbang. I have no idea why.
#10 Post by SHEEPMAN! »
Yeah and trim does not play w/ide. Learn something new every day . Sent from jtb1
