Bluetooth question
Tactmedic
Bluetooth question
#1 Post by Tactmedic »
I don't see how to turn on the BT on this MK3 is there a trick?
CF-C2AKFZGLM My newest one :)
Re: Bluetooth question
#2 Post by SHEEPMAN! »
The A means no integrated options (like bluetooth). The TP are strange on the "old configurator". (KQPATPM) IMHO.
Maybe the Panasonic configurator would shed some light. Nope. :(
See the big arrow up there /\? Click and look for old configurator index htm. public_downloads/Old_Configurator/index.htm
Does your MK2 have bluetooth? Added on if so.
http://www.pcworld.com/product/1337463/ ... ebook.html No mention of bluetooth.
J'd
#3 Post by Shawn »
Bluetooth is an easy swap from your other unit.
#4 Post by SHEEPMAN! »
According to configurator they all lack bluetooth. Of course is could have been added.
Easy check is to look under the keyboard bezel. Antenna (OEM) will be on the left side above the keyboard.
Tactmedic
#5 Post by Tactmedic »
So I went on the BIOS and turned it on, windows is showing I have it so I guess I am good to go. I will be swapping keyboards now since this one is not backlit...
#6 Post by Springfield »
Tactmedic wrote:I will be swapping keyboards now since this one is not backlit...
This might be a good deal -- or not, don't know the seller or endorse them in any way . . .
http://www.ebay.com/itm/Genuine-Panason ... 1474854790
#7 Post by ADOR »
You will now just have to decide if you want the rubber backlit or the emissive one.
Tactmedic
#8 Post by Tactmedic »
I had an emissive one from my parts CF-30 so all is bright in the world :)
