Landed here l
Landed here l
This where I need to be so
Will search around and have a look around. The cf 30 might be. A better option for me
And pitfalls and warnings would be appteciated.
Before I get a scud did
Will need to brush on my terminology jargon
Re: Landed here l
Moderators feel free to delete this one
Re: Landed here l
A CF-30 is a good Toughbook to start with....I only have a few (8)
Re: Landed here l
Ok toughasnails
Spill the beans
And share the love of the cf-30
Spill the beans
Re: Landed here l
Well with the CF-30MK2 and MK3 are fast with W7 4GB memory and a SSD installed. Great battery life, 4+ hours.
Re: Landed here l
A little advice. If you buy a CF-30 get one that is complete because if you buy a parts 30 its going to cost you a lot by the time you get a caddy, HDD or cd-rom + other stuff. It could end up costing you twice the price you paid for the 30.
Re: Landed here l
Your right i was looking at the other posts regarding buying tough bookstoughasnails wrote:A little advice. If you buy a CF-30 get one that is complete because if you buy a parts 30 its going to cost you a lot by the time you get a caddy, HDD or cd-rom + other stuff. It could end up costing you twice the price you paid for the 30.
For cheap or even more
From snake oil vendors
Only to be caught out by not reading the small print on the ad and so on
Any tips or advice
To spec up a fully rugged cf30
And must have features
Is great thanks in advance
- Silver Trooper
Re: Landed here l
If you are interested in a CF-30, I have a MK2 and a MK3 for sale, both are complete with W7 loaded. Let me know if you are interested as I can give you a better price than Ebay...
Re: Landed here l
Still faster with 8 GB of RAM and x64 OS installed....toughasnails wrote:Well with the CF-30MK2 and MK3 are fast with W7 4GB memory and a SSD installed. Great battery life, 4+ hours.
Re: Landed here l
I need to delete one of these as they are duplicates.
Should I delete this one or the other one?
