Screws Sizes
Screws Sizes
#1 Post by Shawn »
Base screws are M2 x 6mm
GPS screws are M2 x 8mm
Antennae cover screws are M2.5 x 5mm
Lid screws are M2 x 4mm
Hinge screws are M3 x 8mm
Hinge cover screws are M2 x 4mm
Hand strap screws M3 x 8mm
Keyboard holder screws are M2 x 4mm
Door hinge screws are M2.5 x 3 mm
Here is a search to get to started
http://www.ebay.com/sch/i.html?_odkw=st ... t&_sacat=0
Re: Screws Sizes
#2 Post by Rob »
WHOAH..... STICKED!!!!!!
Re: Screws Sizes
#3 Post by ADOR »
Looks good. I can finally see the pictures. back states side.
Euphoria
Re: Screws Sizes
#4 Post by Euphoria »
Awesome!
There's just one missing ;) the screw size for the official USB extension.
I have an idea that will require this knowledge :D
Re: Screws Sizes
#5 Post by Shawn »
The USB attachment screw seems to be a M2.5mm diameter screw.
The length will be impossible without knowing what device will be attached to the USB port.
I can not edit my original post without all of the images breaking, so I will leave it as it is.
Euphoria
Re: Screws Sizes
#6 Post by Euphoria »
Would you happen to know what screw size is needed for the motherboard? The CF-19 I have is missing a number of them.
Also the screw for the WWAN and RAM/Camera doors, missing one of those as well.
Re: Screws Sizes
#7 Post by Shawn »
No idea on the motherboard screw size or the WWAN door.
WWAN door I can figure out easily.
Motherboard screws may be different for different locations.
