Wrong memory?
Tactmedic
Wrong memory?
#1 Post by Tactmedic »
So I bought this-
https://catalog-retail.amazon.com/abis/ ... P&qid=&sr=
but when I installed the computer wouldn't boot. I removed and put the original in- no problem. looks to be the right one but maybe its for a Mk2 or Mk3? Not sure...
I have a Mk1...
CF-C2AKFZGLM My newest one :)
Re: Wrong memory?
#2 Post by toughasnails »
That should work...maybe bad memory
Tactmedic
Re: Wrong memory?
#3 Post by Tactmedic »
toughasnails wrote:That should work...maybe bad memory
I was thinking the same thing, sucks because I was really excited about adding this...
What has been the best ram for the CF used... I didn't want to do the "used" ram from ebay but might have to as Crucial ram is like $75 :pat:
Tactmedic
Re: Wrong memory?
#4 Post by Tactmedic »
I did some research and it seems that this is the wrong memory for the Mk1. The Mk1 uses this one -
2048MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v
found here-
http://www.memorystock.com/memory/Panas ... 33MHz.html
anyone deal with this company?
Re: Wrong memory?
#5 Post by toughasnails »
I get all my memory on ebay and never had a problem. $25.-$30. For 4GB
Re: Wrong memory?
#6 Post by toughasnails »
Tactmedic wrote:I did some research and it seems that this is the wrong memory for the Mk1. The Mk1 uses this one -
found here-
NO...No...No...This is the right memory. It can use 4200 , 5300 and 6400 . Trust me I use this in mine
Re: Wrong memory?
#7 Post by ADOR »
Here lately I have had several sticks of used ram that "should" of worked but won't for some reason. Then stick them off into a non-toughbook and they work fine. This was in the CF-T8 Mk4, It has 2 GB on board but out of the 12 sticks of ram I had ranging from 512 mb to 2gb would not let the unit boot at all. Also had this happen on a Newer T7.
Tactmedic
Re: Wrong memory?
#8 Post by Tactmedic »
So is it due to the bios? It reads the original 1GB just fine but not the new out the pack 4GB (2x2GB)... strange..
Re: Wrong memory?
#9 Post by toughasnails »
Are you installing both of the 2GB at the same time ? Maybe just try one 2GB stick.
Re: Wrong memory?
#10 Post by Shawn »
Could be bad memory. Could be fake memory.
Do you have a way to test it in another notebook? I think there is a program called Memtest that people use.
Post a photo of the actual memory you have.
Maybe it is high density...High density ram is cheaper, but very finicky to get to work.
