Process tweaking tool
#1 Post by Springfield »
A while back someone was recommending a process tweaking tool, might have been Ador? Anyone recall that, or have a recommendation. Trying to track down some funky stuff on a friend's PC . . . .
Re: Process tweaking tool
This works well to see what's running and turn things on and off..
The ultimate troubleshooter.......
http://www.answersthatwork.com/TUT_page ... mation.htm
This one's more for adjusting
UWT..
http://www.thewindowsclub.com/ultimate- ... ws-7-vista
#3 Post by toughasnails »
UWT..
and this one is FREE
#4 Post by ADOR »
The one I was talking about was Process explorer, they make standard and portable version.
http://filehippo.com/download_process_explorer
Also if you want to cross scan the system without installing another Antivirus I use these portable antivirus's from time to time with good results.
http://www.mcafee.com/us/downloads/free ... inger.aspx
Stinger comes ready to go after you download it, but you have to download the new version to update it.
The next two can be updated and ran portable.
http://portableapps.com/apps/security/clamwin_portable
http://portableapps.com/apps/security/spybot_portable
Here are some more, but I haven't personally used them.
http://portableapps.com/apps/security/k ... r-portable
http://portableapps.com/apps/security/h ... s-portable
I have talked to Shawn about the one he uses, but just haven't had a need/chance to try it out yet.
