Cf-19 MK3 Front Panel Buttons
Banshee
#1 Post by Banshee »
Just noticed that since I've installed Windows 8.1 Pro x64 on my Mk3 CF-19 that some of the front buttons don't work.
The brightness works and the "key" button works and brings up the lock screen options, task manager etc etc however, the keyboard button doesn't work and neither do the other two even though I'm not sure what they are for.
I've installed the button driver and button manager but still no luck, also when searching for tablet buttons from Windows Search I get the following message appears
Any ideas guys?
noxtreme
Re: Cf-19 MK3 Front Panel Buttons
#2 Post by noxtreme »
Have you tried the display rotate driver?
Toughbook CF-19 Mk7 GPS 4G Lte Emissive KB || Mk5 GPS 4G Lte Emissive KB || Mk4 GPS 3G Emissive KB || Mk2 3G Emissive KB
Banshee
#3 Post by Banshee »
noxtreme wrote:Have you tried the display rotate driver?
I haven't but will now :headbang:
canuckcam
#4 Post by canuckcam »
Did you install that display driver from Intel? Try uninstalling that. The display driver was the source of Fn issues on Windows 7 on my CF-30. The display drivers for the Toughbook are modified and not stock.
#5 Post by Rob »
Make SURE SURE SURE the common components are installed! :)
#6 Post by kode-niner »
Now if only I could get those to work in Linux...
