Linux compatible headset w/mike INFO NEEDED
#1 Post by SHEEPMAN! »
I'll start with the incompatible at my level of expertise....I'm D- grade but learning.
Logitech 800 does not play well with Linux. Excellent with Windows XP and 7.
definition: NOT PLAY WELL........means it is not plug and play from either Bluetooth or using the included dongle.
Dongle kills audio but does not reset it after use.
So I need a headset that includes Linux driver or one that the driver is already in the current Linux package. Let's say Ubuntu 12.04 and newer.
Recommendations?
UNCNDL1
Re: Linux compatible headset w/mike INFO NEEDED
#2 Post by UNCNDL1 »
What about posting a question in the "newbie" section here:
http://forums.linuxmint.com/viewforum.php?f=90
or here:
http://forums.linuxmint.com/viewforum.php?f=49
:violent:
Have you updated your alsa yet?
http://askubuntu.com/questions/150887/s ... d-speakers
mklym
#3 Post by mklym »
Are you looking for USB or Bluetooth?
Try Turtle Beach if USB. See here:
http://ubuntuforums.org/showthread.php?t=1222830
#4 Post by ADOR »
When I get home I can try out two different turtle beach. One wired, one wireless that belongs to my oldest boy. I have a set of wired Creative Fatal1ty I can test out once I get it all loaded.
UNCNDL1
#5 Post by UNCNDL1 »
Here's a review for a Logitech set used in Linux
http://blog.brendel.com/2011/06/wireles ... ux-my.html
