Once I had the OS in, I went to Intel and ran the driver finder program. I downloaded the chipset, video, LAN and WLAN drivers. I then installed the chipset driver and rebooted. Actually, I rebooted after each driver/program installation.
I had already downloaded the Panasonic drivers and programs for a CF-52P/Q running W7P64-bit. Basically, I followed the pdf, even though it seems to list the drivers and programs in alphabetical order. After installing the video driver, and rebooting, I installed the newer driver from Intel. The LAN driver used was the Intel driver. The WLAN from Intel would not install. Or so it seemed.
Once I had all the Panasonic drivers and programs I wanted to use installed I did MS updates. It installed the drivers for the Sierra Wireless WWAN card. I have not installed software for it so have not tested it.
The only problem seems to be the PC Info Viewer. It gives a SetDiag.exe error about failed to start because it's side-by-side configuration is incorrect. Any ideas what the problem is?
Other than that, everything seems to be running okay. The unit boots, from the disappearance of the Panasonic boot screen to the appearance of the login box, in about 12 sec and shuts down in about 5 sec. I have not done any optimizing of the OS for the ssd yet, so those times should get shorter.
One thing to note is that I did not use any Panasonic touchscreen drivers. W7 detected and installed drivers for the touchscreen. I calibrated it through the PC Tablet program in the Control Panel and it has been perfect.
All that is left to do is install third party programs.
