CF31 hot keys
CF31 hot keys
I now have win 8 pro working on my CF31, the only thing I have found not working is the screen brightness hot keys, whick I use a lot out in the garage or outside for my digital shop manuals for my JD tractor or my '59 chevy pickup. I have removed & reloaded the drivers from the Panny win 8 help web page many times but can quite get it. Has anyone else upgraded from the factory installed win 7 pro. to win 8 pro. & got all the hot keys to work? I have done several searches but have not found any help.
CF-31 mk2 ToughBook, 320Gb 7200 rpm hdd, Win 8 Pro, Upgrades = 8Gb Ram, Super Multi Drive, Desktop Dock, Media bay battery, Emissive Keyboard, 128Gb SDHC.
More upgrades to follow, ie. GPS, USB 3.0 PCMCIA card & SSD.
JT-B1 ToughPad, WiFi, Android 4.0 powered, 16 Gig RAM, 32Gig SDHC
http://toughbooktalk.com
http://www.sevenforums.com
Re: CF31 hot keys
You've probably seen these but I replaced TEST with CF-31 hotkeys and got several
hits. Conflict with stand-by was one.
Yours sounds a little like either a missing or more likely install done out of order. Hotkey, appendix etc.
Do you have a picture of your device manager?
http://www.google.com/search?btnG=1&pws ... Fpanasonic
Re: CF31 hot keys
Thanks for the help, I now have all the hotkeys & the popup menu working like new, it must have been the order of installing the drivers as reinstalling the video driver & then the hotkey driver & app fixed it.
Re: CF31 hot keys
Good show.
Re: CF31 hot keys
Hello,
I am having a similar problem, but on windows 7 pro. I am much less computer savy than others, I am working on that! So I can change my brightness with my hot keys but within 3 seconds it goes right back to the 50% brightness. Thanks gents
Re: CF31 hot keys
Most probably drivers were installed in the wrong order.
What's full model number please?
How was installation done?
