CF-19 MK-4 WWAN
TOUGHNOVIS
CF-19 MK-4 WWAN
Hi I have a cf-19 mk-4 I installed a wwan card and it is not reconized in the bios I seen on NBR an article but the link to the bios flash was removed.Their is no dip switches and I tried removing battery and holding power switch for 60 seconds with no luck .Can anybody help.Thanks in advance
Re: CF-19 MK-4 WWAN
You need to use the cf-52 BIOS flash to flash 04 for the Gobi via dos.
TOUGHNOVIS
Re: CF-19 MK-4 WWAN
Can you please Rob send me a link to the download.Thank you
Re: CF-19 MK-4 WWAN HEY ROB
Rob,
Is that SPGOBI2.zip that you are referring to. I have that still available in my dropbox. Let me know and I'll get with the OP.
TOUGHNOVIS
Re: CF-19 MK-4 WWAN
Please do Thank you That is the file I was looking for.
Re: CF-19 MK-4 WWAN
I don't have this.
Jeff. Please and thanks!
Re: CF-19 MK-4 WWAN
Done and your welcome.
Re: CF-19 MK-4 WWAN
Bob,
I messed up the email address. Yell at me if you don't get the link. Should be o.k. now.
TOUGHNOVIS
Re: CF-19 MK-4 WWAN
Got it.Thank you and God bless you
Re: CF-19 MK-4 WWAN
Jef! Can you also send me this zip file pls!. I will try to install a gobi2k to my new to me MK4. Thanks
