CF-29 GPS patch?
CF-29 GPS patch?
#1 Post by Rob »
I know for the CF-30's they have em. But they don't appear to work on the CF-29's
Is there a different patch that I'm missing?
Re: CF-29 GPS patch?
#2 Post by ADOR »
I know I ran the mouse jump patch on my 29 if that is the patch you are talking about.
#3 Post by Rob »
Yes, thats the one... But my customer is saying that its not working.
This one: public_downloads/index.php?dir=GPS%20Re ... atch%20XP/
#4 Post by ADOR »
Not working because it won't extract or mouse is still jumping? You need to disable gps run it then re- enable gps.
#5 Post by Rob »
The mouse is jumping.
#6 Post by ADOR »
I see that toughbookdrivers has the gps patch for the 29's still, and on some Mk's it lists another GPS file called GPS filter. Sure the panasonic site still has it, just haven't searched for it there yet.
#7 Post by SHEEPMAN! »
HOW TO:
1. f2 to bios. Set to defaults then before F10 go over and disable gps....then F10.
2. there are two files in the gps patch folder. One turns it on (modifies registry) and the other turns it off. Just use one.
Run "skipenum.reg".
When the cursor of mouse is jumpy, please
shut down PC once.
When uninstalling, please execute
"enablenum.reg".
Above quote from jp site.
My interpretation is run skipnum.reg then re-boot.
STARTING OVER:
If this is not working the thing is scrambled, and a pull power hold switch over to drain system may be indicated. THEN run enablenum.reg re-boot and start from the top.(see below)
THEN:
1. F2...default...disable gps F10.
2. skipenum (double-click the link in GPS folder)
3. re-boot...set to defaults...see if GPS is on auto and F10.
