Ledco dock
subcaptian
Ledco dock
#1 Post by subcaptian »
Hey everyone, I have a question regarding a Ledco vehicle dock, specifically the pass-through antennas. In a model with dual pass through, what antennas are passed through? Cellular and wifi, or cellular or GPS?
Re: Ledco dock
#2 Post by Rob »
It depends on the unit.
What is the full model number on the Toughbook going into it?
subcaptian
Re: Ledco dock
#3 Post by subcaptian »
My unit is a CF-19CHB83BM.
Re: Ledco dock
#4 Post by Rob »
UpperWWAN/Lower:WLAN
subcaptian
Re: Ledco dock
#5 Post by subcaptian »
Would it be possible to reconfigure it to use WWAN and GPS?
Re: Ledco dock
#6 Post by Rob »
No
subcaptian
Re: Ledco dock
#7 Post by subcaptian »
So, is there any way I can run a roof-mounted gps antenna?
Re: Ledco dock
#8 Post by Rob »
I would use a USB GPS.
That's what I did.
Re: Ledco dock
#9 Post by ADOR »
Are you just not getting a good enough signal from your standard antenna? I have used my 19 with GPS a few times in the car and haven't had a problem with. Then again I live in Louisiana not Alaska.
subcaptian
Re: Ledco dock
#10 Post by subcaptian »
As for reception, my problem is that my vehicle is a 1991 F250. A steel box with almost zero reception. I'm a little disappointed that the only all in one antenna is one endorsed by Panasonic that costs over 300! So, I'll keep looking for alternatives, and I'll be open to suggestions anyone might have.
