GPS
kljw
GPS
#1 Post by kljw »
hi
i am looking to upgrade my toughbook, but would only do so, if the CF31 has, or can have a GPS unit fitted, as per my CF30, can this be done?
many thanks.
Cheers
Keith
Re: GPS
#2 Post by ADOR »
Yes, GPS is a factory option. The only options you have for the 31 right now are factory, custom toughbooks version, bluetooth, usb or mod yor own. If you do your own you may be without help as many board members don't have one yet.
Re: GPS
#3 Post by Springfield »
Your timing is good -- Custom Toughbooks just put out 2 new kits for CF-31:
http://www.ebay.com/itm/GPS-kit-for-Pan ... 1028382946
http://www.ebay.com/itm/GPS-kit-for-Pan ... 1028383187
Re: GPS
#4 Post by ADOR »
I have used one of his CF-29 and CF-30 kits. I pulled it out of my CF-30 Mk1 before selling it. I have a CF-31 kit already at my house just waiting on getting the 31. I don't think anyone else right now is doing a aftermarket GPS for the 31.
jamesavrit
Re: GPS
#5 Post by jamesavrit »
What is the differance between the 2 kits that are offered from customtoughbooksdotcom
Re: GPS
#6 Post by Rob »
jamesavrit wrote:What is the differance between the 2 kits that are offered from customtoughbooksdotcom
He's on this site. Please send him a PM! memberlist.php?mode=viewprofile&u=136
