Sandisk Cruzer Fit USB flash drive 32GB Got mine on sale for $24.99 each. I think they are $29.99 now, but you can ask for the old price and they will give it to you. Regular price is something like $60. One fits perfect under the back cover of my CF-30. The second one fits with just a tiny modification. You have to remove just a tiny bit of metal from the brace on the back cover. It does not affect the cover in anyway. 64GB closed up, in the case, good to go. Hope it helps!
A couple of pictures:
Package
USB Stick by Itself
Installed
Installed with Small Mod
