I feel stupid asking this-Enabling wireless on CF-72
packetloss
#1 Post by packetloss »
I recently bought a CF-72 and I can't figure out how to turn the wireless on. I've searched for a switch, but no dice. I know it has a wireless card because I saw it when I had the case opened up (had to repair some stuff when I got it) and it shows up in lspci with the following
02:03.0 Network controller: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection (rev 05)
So, how do I turn the damned thing on?
packetloss
Re: I feel stupid asking this-Enabling wireless on CF-72
#2 Post by packetloss »
Google is no help, no threads here seem to have my answer either. Is there really not a switch or something?
#3 Post by teo »
Did the wireless option appear on the bios? If yes! Is it enable? Hit F2 during bootup to direct you into bios setup.
#4 Post by SHEEPMAN! »
What version of Linux are you using. There have been some very nice upgrades to include most of the wireless drivers for Intel.
What Intel Chipset?
dmesg grep | Intel
There were some issues requiring an upgrade with 855GM. Appears to be mostly graphics related.
Good luck,
http://intellinuxwireless.org/
Gear6
#5 Post by Gear6 »
2200bg should be supported out of the box in Linux for some years (firmware included).
Try the rfkill tool, to see whether it's block in SW or HW.
$ rfkill list
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
If it's soft blocked, then unblock it:
$ rfkill unblock wlan
If it's hard block, then usually it's the hardware switch, but in your case it may be
disabled in BIOS.
what Linux flavor and version do you have ?
C1mk1&2, CF19mk4, CF30mk1&mk3
packetloss
#6 Post by packetloss »
Thanks guys, I've been busy the last couple days and haven't been able to check the board. It'll take me a minute to read through these replies and try them. I'm using Arch linux and I never even considered checking the bios, DOH!
Thanks guys, I'll let you know how it works out!
packetloss
#7 Post by packetloss »
Intel chipset is 845
rfkill list returns nothing
#8 Post by ADOR »
Are you sure the card is good? I had a CF-T2 one time that I had hell getting the card to show up, then when it did never worked right. Replacing the card solved the issue.
Also try running another Linux live CD to test and see if it will work under it.
packetloss
#9 Post by packetloss »
I think testing with another distro is gonna be my next move. It shows up fine in lspci. Im inclined to call it good.
Gear6
#10 Post by Gear6 »
as for linux live CD (i.e. no install required) check this suggestions here:
http://forum.notebookreview.com/panason ... ost8810768
