When you pop off the key from the keyboard it is made up of 5 parts. Main part you see is the letter key. It has 4 clips on the bottom, two on each side of the key. You have two white hinges that have 6 points of attachment together. Two on each bottom connecting to the keyboard base, two in the middle allowing the parts to hinge together. There is a clear silicone spongy piece under the white hinges. That is the part that presses the circuit so the keyboard circuit knows it has been touched. There is one last piece to this puzzle. There is a clear plastic piece that slips under the top lip of your two white hinges. This piece serves two main purposes, one is to push the silicone part down, two it is the part that the key physically clips too. The only tools I used were two small flat tipped jewelers screwdrivers, my fingers and lots of patience.
Below you can follow along as I replace two keys.
The clear part the keys hold too wedged next to the emergency button for you to see. There is a long side and short side. Pay attention to how it goes during disassembly.
