My digitizer is jammed at the top of the screen
eddie8
#1 Post by eddie8 »
Hello all
I bought a cf-18 off of ebay and when I try to use my digitizer it shows the arrow at the top off the screen and i cant get it to move. I tried the screen calibration proceedure but cant get the arrow to leave the top portion of the screen to do the procedure. Any ideas?
Thanks.
Re: My digitizer is jammed at the top of the screen
#2 Post by Rob »
Did you try a different digi pen? Sometimes goofed up digi pens can cause WEIRD things to happen.
99% of the time its a bad digi pen.
FWIW: almost ANY digi pen will work, including the CF-19 digi pens
eddie8
#3 Post by eddie8 »
Thanks rob for the reply. I fixed it. I ended up installing the wacom pen digitizer driver. Now it works perfect!!
