CF-29 Hard drive
toughbook2011
CF-29 Hard drive
#1 Post by toughbook2011 »
Hi can someone recommend a hard drive so i can upgrade the 60gb in at the moment?
My toughbook is CF-29ETPGZZZ.
I have been looking at various sites but dont want to order the wrong one. :help:
Any info would be great.
Re: CF-29 Hard drive
#2 Post by Rob »
Searching the forums would be a gooooood start... :doh:
You need an IDE drive
toughbook2011
#3 Post by toughbook2011 »
hi, i have had a look about on the forums just cant seem to find a place to order one from, i was looking at a 2.5 ide ata 7200rpm 100-200 gb.
Any ideas?
thanks
#4 Post by Rob »
#5 Post by toughasnails »
We are now recommending the Samsung SpinPoint Series 5400 RPM single-platter HM160HC drive, although the Western Digital Scorpio Series 5400 RPM drives also have a following due to their near-silent operation. Both have much larger cache and improved access times which produce performance nearly as impressive as the above-mentioned TravelStar drives, and their greater efficiency yields noticeable battery life improvement and reduced heat generation.
Check this ebay search out, I have picked up 2 so far for under $40.00 :D
http://computers.shop.ebay.com/i.html?_ ... SRCHX:SRCH
