Will a port replicator for a CF-50 like this one:
http://cgi.ebay.com/Panasonic-CF-50-Doc ... 0722233096
Fit a CF-51 and/or CF-52?
I know the CF-27/28/29 series will all fit equivalent port reps/docks although there are limitations with older USB 1.1 etc. Similar situation here, or no?
Port replicator compatibility
- Springfield
Re: Port replicator compatibility
As mentioned in the eBay deals thread I'd like to know myselfSpringfield wrote:Will a port replicator for a CF-50 like this one:
Looks like the same one for the cf-50 I got in my hand and no, the port is on the left side for a cf-51, the cf-50 is on the right side. unless you plan to mod it I don't think it will fit th cf-51, at least the core duo models.......Driller
Ahh... And I think I recall my mom's CF-52 having the port on the bottom... So that would rule out the CF-52 as well...
- Silver Trooper
The 52 replicator is entirely different and will not work with previous models.
