Microphone?
- Silver Trooper
Microphone?
I just bought a 34/933 with what appears to be a bad screen (it only displays white). I was in the process of swapping screens with a 700MHz donor when I noticed a second wire bundle coming from within the LCD case, red and black with a white connector. I looked on the mobo and could not find a connector within reach that it would team up with so I took apart the LCD to determine what was on the other end. Come to find out it was a very small microphone. Has anyone seen this before and if so where does it connect on the mobo? I am fairly certain the mobo is correct as it does have the correct processor (or are they able to be swapped?) Ideas?
Re: Microphone?
Trooper..As far as I know the only unit that has a microphone builtin and I think it is an optional to are from 300mhz to 400mhz unit of CF-m34. Anyway, you can check the unit of yours if there is a connector for microphone located below the slot beside the inverter connector on the mbo. but i my guessed its not present. Just give it a quick look I don't remember now since i handed the 933mhz. Right now I only have two 700mhz and 1ghz unit of cf-m34.
