Hi
as i now discovered that i have a MK and not a MK3, what are the differences between the Mk1 and MK3? and can the changes be made to upgrade? and is it worth it?
Differences between Mk1 and MK3
- Silver Trooper
Re: Differences between Mk1 and MK3
Go here first:
http://forum.notebookreview.com/showthread.php?t=241106
After you go through it and other stickies for the CF-29, if your questions are still unanswered, we would be happy to assist. Not trying to be rude or put you off, but the same questions (or very similar) have been asked/answered many times before. Plus, those stickies are a HUGE source of info on the 29. Good luck and welcome to the disease known as Toughbook!
hi
thanks for the info. i have look through the forum, and have found info on the 29, but it was the differecnes between the cf30 mk1 and mk3.
Cheers
Keith
Keith
- Silver Trooper
My mistake, I was looking at several threads and forgot you have the CF-30, not the 29. Try this one instead:
http://forum.notebookreview.com/showthread.php?t=264961
There are some significant differences between the MK1 and the MK3, and it probably would not be in your best interest to try and upgrade to eliminate those differences. However, there are still many things you can do to yours. I have not had the privilege of owning a 30 as of yet. But there are several guys on this and the other forum that have CF-30's and have done many mods to them. As I said, look over the thread specifically for the 30's, and then let us know how we can help.
