screen change
screen change
Hi
the screen on my used cf30 is a klittle used, can this be changed or refurbished?
cheers
keith
cheers
keith
Cheers
Keith
Keith
Re: screen change
Touchsceen, or normal ?
Mk# ?
Restate the issue with the screen , as I don't understand
Alex
Mk# ?
Alex
Re: screen change
Hi
i think it's a mk3, although i will need to check now i know how. the stylus has been used allot on the screen, and therfore is scratched quite badly. i was thinking about changing it, if possible, to bring it back to as new condition.
Cheers
Keith
Keith
Re: screen change
What is the full model # CF-30??????. It's on the bottom
Blair
Re: screen change
Hi
i don't have number on the bottom (see another post) i will need to access the BIOS and find out that way.
Cheers
Keith
Keith
Re: screen change
Does your screen not have a screen protector on it? You can buy them new on ebay for about $30.00 .This is the link that toughbook buys his from http://cgi.ebay.com/Screen-Protector-Pa ... 19b2229e8dkljw wrote:Hi
Blair
Re: screen change
Toughasnails
thays exactly what i am looking for! thank you. are they easy to change?????
Cheers
Keith
Keith
Re: screen change
Well that is good news. I have been lucky that all my toughbooks I have bought have been in good shape . I have not changed one before but someone on here could tell you or try NBR. I know it was talked about on NBR a while back
Blair
- Silver Trooper
Re: screen change
http://forum.notebookreview.com/forumdisplay.php?f=1012kljw wrote:NBR?
If you are not already a member, you will need to register to get a user ID and password. That is the "other" forum we often refer to around here. Many of us were members there before Rob (and others) started this forum for to "narrow the field" so to speak. Now we all get to comment on both forums!
