what mark of cf30 do i have
kljw
#1 Post by kljw »
Hi
just picked up a used cf30, was advised by seller that it was a mk3. having now looked over more carefully, all is fine, but there are no markings on the bottom to say what mark it is. the only ref nuber is T1200Z.
any suggestions on how to find out?
Cheers
keith
Cheers
Keith
Silver Trooper
Re: what mark of cf30 do i have
#2 Post by Silver Trooper »
Go into your BIOS and it will tell you your full model number and you can also determine your mk #. Just hit F2 as it boots.
kljw
#3 Post by kljw »
Silver Trooper
thanks for that, will give it a go and see what pops out.
cheers
keith
Cheers
Keith
kljw
#4 Post by kljw »
Hi
my model number is CF-30CTQAZBM, how can i determin the mk from this?
Cheers
Keith
Azrial
#5 Post by Azrial »
kljw wrote:Hi
You have a:
Intel Core Duo L2400 1.66GHz (Centrino), 13.3" Touch XGA (1000 NIT), 512MB, 80GB, Intel 802.11a/b/g,WinXP, TPM1.2, Bluetooth, No Optical sold in North America.
Go here for more info: http://www.config.toughbook.com/pcsc/co ... tinued-all
kljw
#6 Post by kljw »
Hi
thanks for that, there are a few thig different, in that i have 2gb ram, 160gb hard disk. but the rest seems th same.
but can you tell me what MARK it is, i.e mk1/3 ??
Cheers
Keith
Silver Trooper
#7 Post by Silver Trooper »
When you hit F2, look at the version of the BIOS that is installed, it will be the number next to the "V". If it starts with V5.XXX, you have a MK5, if it says V4.XXX, then it is a MK4.
tomcat57
#8 Post by tomcat57 »
Its a Mk-1
luebke5530
#9 Post by luebke5530 »
The first letter of the model number will tell you what mark it is:
EX: CF-30FTSADAM
CF-30C.....=MK1
CF-30F.....=MK2
CF-30K.....=MK3
same for the CF-19.
Hope this is useful to someone :D
:cheers:
-Steve
