So the damn touchscreen is being funny with the calibration now... ALL POINTS of the ENTIRE screen work EXCEPT where the task bar is along the BOTTOM. What gives?!?!?
I've calibrated it so many times that my hand hurts
Any useful knowledge?
Thanks guys!
The latest on my CF-30
- Silver Trooper
Re: The latest on my CF-30
What exactly does it do when you try to calibrate along the bottom? I assume the X's appear, but when you go to touch them nothing happens?
No, when the X's show up I can hit em all just FINE... Hit enter then hit save & close...
It's only off by like 1/4"... but its enough to piss me off!
- Silver Trooper
I know that it cold not of happened, but it sounds as if the touchscreen plate has moved in relation to the LCD, even though it would be slight.
