I don't have the seal and plastic tape because my fingerprint reader is a used one , so I've to prepare the tape myself.Rob wrote: ~six little rubber seals and plastic tape things either... Would I just put those where I feel fit?
I download the CF-30CTGUPRINT from your site, page 44 to 46 is the assunble Instruction Manual of the Finger Print Assy.
The cover is a loose one,maybe water will get in the cavity, but the main chassis is safe.Rob wrote:Also what about the water aspect of this mod... Can the fingerprint reader its self get wet or is that an no no? Does that little cover seal it entirely from water?
Ref:Rob wrote: Now what about the software to run it?
Supplementary Instruction for Finger Print Reader HS1206-1018 , DFQX5628YA
http://pc-dl.panasonic.co.jp/cgi-bin/it ... main=11497
Hello Azrial , I use the CF-29 and CF-18 to prog. the radio , no problem.
