Hi picked up a cf-19 and cf-18 at a flea market
Any 1 have a hard drive caddy or can point me to 1 thanks
Will part out the cf-18 if any 1 is keen
WTB caddy for a cf-19
Re: WTB caddy for a cf-19
And if anyone can tell me if the cd-18 and cf-19 take the same internal caddy ?
The caddy is different. They swapped from a IDE to SATA drive going in the 18 to the 19. If you have a Mk1-2 CF-19 some of the parts on the 18 will swap over. Less will swap over on a Mk3-8 as the chassis was changed up. Post your model numbers up when you have time.
The correct and complete caddys are readily avalible on eBay. And usually pretty cheap.
CF-3110778CM, CF-19ADUU51M
